In Reply to: Stabilizer link bars posted by ScottNC on April 16, 2013 at 10:32:14:
Scott-
Others have given you good advice here. So...
Let's slow down a minute and take it one step at a time. If everything is set up correctly, there is no need to monkey around re-adjusting the fender brackets each time you change implements. Once they are set, they are good to go for any implement needing the stabilizer bars. Period. First, there are two sizes of the original fender brackets. Note the pin location height on each. Starting with the 600 Model, the distance from the lift pins to the fender bosses was slightly higher thus the bracket pin location changed- note picture. Next, using the original or aftermarket/angle iron style doesn't matter, you just need to make sure they are mounted correctly. The pin face faces in -closest to the diffy case.
Picture this: Taking your left hand, make a 'gun' with you thumb and index finger. Now turn it upside down so your thumb is pointing down and your index finger is pointing to the right. This is how the bracket that bolts to your right fender is set. The thumbnail area has the link pin and the index finger has the fender bolt mounting holes. The bracket link pin and lift pins now should align with each other. Now take both of your index fingers, point them at each other almost touching. This is how the pins locate correctly. Now, once you have positioning correct, snug down fender bolts, but do not tighten completely. Repeat procedure for the left side using opposite symmetry.
Next step is to get a back blade, bush hog, or rear finish mower that you will use the bars with and hitch to the tractor lift arms. Attach a top link too. Attach one stabilizer bar to the left side implement pin and latch with a linch pin. Attach a bar to the right side implement pin and latch as well. Take the left bar end nearest the point where it will attach to the bracket pin and fit it onto the link pin on the bracket. This may take some 'to and fro' motion to get it to fit on and one reason we left the brackets loose. Do not tighten down fender bolts yet. Repeat procedure now for the right side. Latch fender bracket link pins with linch pins. Once implement is attached with bars in place, still loosely bolted down, proceed to final adjustment.
Final Adjustment: At this phase you will proceed with extreme caution working slowly so you do not bend or break anything. Be sure your Finger Control lift is set at the bottom of the stoke -all the way DOWN. Start tractor. SLOWLY begin to raise the lift observing that the bars are not binding or that anything sounds or looks like it is under stress. There may be some 'positioning' of the fenders as they self adjust themselves to the bars. If something doesn't look or sound right, drop the lift arm right away and determine what it is that is out of sync. You will do a series of up and down lifts to ensure that the positioning is set correctly. Correct positioning is when the lift is all the way UP and the bars don't pinch, bend, bind, crack, break or otherwise fail. When you have a warm & fuzzy about the lifting, now you can secure the fender bolts down tightly. Always repeat the lift sequence a few times once the fender bolts are tight. That's it -the bars are set to your lift. There is no way they need to be changed.
Once this procedure is successful, you won't need to muck with the setting again. You should be able to go from a mower to a back blade to a disc harrow without any worry about touching the bar settings. You might want to do an occasional routine PM check to verify they didn't move. Jamming a snowbank full throttle can cause one side to move.
This method is a proven system to set stabilizer bars. I have seen bent lift arms, blown hydraulic pumps, and bent and twisted bars because the stabilizer bars, mostly the brackets, were installed wrong. One reason is the new, aftermarket style brackets have multiple pin location holes to use with different tractors, and if you don't have the pins in the right hole for your tractor, you will end up with a disaster. Most all issues with bars is they are not set up correctly. Either the pins are in wrong position or the brackets are facing the wrong direction.
I hope this helps you and anyone having the same problem...
Posting not permitted in the forum archives.<1366151177">
