I am going to change the crank pulley because the one that is on the tractor is bent. Looking for an easier way than taking the complete front axle off! So, I wonder if I remove the front axle support bracket bolts (6), (it attaches the front axle assembly to the front of the engine)....can I leave the axle attached and just jack the front of the tractor up far enough to remove the big bolt and get a puller on the crankshaft pulley?? I also toyed with the idea of giving the bent pulley a whack to adjust it back into alignment but wondered if it was cast and would break? Anyway.............David
Posting not permitted in the forum archives.<1366478266">
