In Reply to: CM HALL Headlights - Dates Needed posted by Tim Daley(MI) on May 03, 2013 at 07:35:24:
CM HALL LAMP CO. logo -Used only on USA made Ferguson TO20 and later tractors-
HALLAMP headlight -Used Only On Ferguson Tractors-
FYI-
CM HALL LAMP CO. DETROIT MICH. USA logo used on the Implement Lamp (1949 - )-
NOTE- The CM HALL LAMP CO. was the only approved vendor by FORD to supply the worklight, p/n 8N15500. The two differences between a FORD worklight and a CM HALL worklight is that the FORD worklight has no bolt retainer riveted or screwed to the inside where the hollow mounting bolt assembles thru, and no logo whatsoever on the housing. 6V lamps were supplied by FORD on both and had TRACT-O-LITE B, MADE IN THE USA, and the FORD script logo on the glass lens itself. The CM HALL logo on the Implement Lamp is located above the switch. All other features are identical.
Posting not permitted in the forum archives.<1367585131">
