In Reply to: Re: Sediment bowl posted by Ernie Adams on June 22, 2013 at 23:55:05:
" can you expand on governor issues "
Yep.
I already have........tip # 14.
But that's not your problem.
As soon as it starts running poorly....not a minute or two later....get off the seat and check fuel & spark.
Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get an old plug w/ the gap open at least 3/16", ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem.
Posting not permitted in the forum archives.<1371997633">
