In Reply to: Re: Naked N posted by RockyMO on July 30, 2013 at 17:38:56:
I fully intend to take it completely apart, differential, transmission, engine, axles, spindles, hydraulic, etc. I plan to go through all bearings seals and gaskets and the engine will be redone as needed (plan to rebuild completely, but it had good pressure and did not smoke, plus the one brass freeze plug suggests a possibility it may have been rebuilt. It was getting coolant in the oil over time so minimum it needs a head gasket, but everything will be checked. If I wasn't planning on doing that I would not have blasted it as I did. I'm interested to see what I find upon taking it apart after this.
Posting not permitted in the forum archives.<1375220958">
