Re: ford 861 clutch
Posted by Texas! on October 08, 2013 at 23:09:57 [URL] [DELETE] :
In Reply to: ford 861 clutch posted by fordmancg on October 08, 2013 at 22:59:55:
You shouldn't need to adjust anything other than the pedal freeplay. If the clutch you are buying was rebuilt (or new?) properly everything should be adjusted correctly. Just to assure yourself it is correct I believe the 3 fingers for the trans pressure plate should be 3/4" higher than the 3 PTO pressure plate fingers. The double clutch for the X6X tractors is a complete, pre-packaged assembly. You just bolt it to the flywheel and go.
Posting not permitted in the forum archives.<1381288197">
