Re: Leak around the lower lift link support pin.
Posted by carl ny on January 21, 2014 at 15:25:51 [URL] [DELETE] :
In Reply to: Re: Leak around the lower lift link support pin. posted by Woodchuck on January 21, 2014 at 15:00:39:
Not to tighten the right side. If you take off the right side you can only tighten the right side. If you take off the left side you can tighten the left side, then remove the ring gear(easy) and tighten the left side. Saves having to take both sides off.
carl ny
Posting not permitted in the forum archives.<1390335951">
