In Reply to: Re: NAA Governor / Carburator posted by WayneIA on May 02, 2014 at 20:20:39:
Good Suggestion Wayne,
I have not got a spring there and checked my disassembly pics from two years ago and sure enough, there is a spring attached to the lever on the throttle rod at the friction plate. This would be problem number one.
No doubt there will be some adjustment required as well as the carb and throttle linkage is from the tractor but the governor setup is fro the donor engine. Will keep Walts ideas in mind when making any necessary adjustments.
As usual, many and profound thanks for the suggestions.
geo
Posting not permitted in the forum archives.<1399116579">
