Re: Mounting 8N generator; 1948 Front Distributor
Posted by Tim Daley(MI) on October 08, 2014 at 11:03:48 [URL] [DELETE] :
In Reply to: Mounting 8N generator; 1948 Front Distributor posted by Acadianbob on October 07, 2014 at 23:35:03:
The tension adjusting bracket on the early 8N generator as shown is part number 10145 and the free end bolts to the bottom of the governor. Without it you will never have proper tension on the generator and it will just loosen itself up if only held on with the pivot mounting bolt. If you don't have this bracket, JUST8Ns.com sells them.
Posting not permitted in the forum archives.<1412780628">
