Re: 8n lift adjustment
Posted by Dean on October 21, 2014 at 14:39:16 [URL] [DELETE] :
In Reply to: 8n lift adjustment posted by Ron8n on October 21, 2014 at 14:14:28:
You will need to remove the lift cover, replace the cam follower and adjust the linkage. Yes, the Zane's jig can be used to perform the adjustments.
Overhaul the cylinder/piston and thoroughly clean the sump while the lift cover is off.
Dean
Posting not permitted in the forum archives.<1413916756">
