In Reply to: Re: Rear Worklight Project posted by Tim Daley(MI) on July 22, 2010 at 12:33:58:
Tim......you say.....The lamps are identical to the Ford blueprint except the CM HALL diamond logo is stamped on theirs next to the light switch.
I think if you check your blueprint.....you will see that the CM Hall or whom ever makes the lights, are required to affix a name to ID the vendor lights. don b
Posting not permitted in the forum archives.<1280259468">
