In Reply to: CM Hall Clips II posted by Steve Dabrowski on March 16, 2012 at 13:29:15:
Hi Steve,
If you check out my Dexta restoration journal (below), starting at photo #551, you will see the restoration of the Butlers headlamps I did for my Dexta.
The headlamps were pretty badly rusted - but I was able to save most of the parts by taking them apart VERY carefully - including the retaining clips. What about the reflectors in your lamps? Were they okay? If not, I used Rustoleum's aluminium Bright Finish paint as an alternative to re-chroming (very expensive). Although, GMP, here in Morgan Hill, might be able to do that reasonably.
Stop in when you're in the neighborhood.
Don
Posting not permitted in the forum archives.<1331929264">
