My 8N has a small leak on the right side lift arm attachment bolt. I've seen posts here that say you need to remove the left trumpet to repair. Is the repair simply tightening the castle nut? Also, did I read a post here once that someone said they tightened this nut by accessing it thru the PTO opening? I can see the nut but seems like it might be quite the chore to actually get the cotter pin off tighten it and secure with a new cotter pin via the PTO opening. Is this really possible?
Posting not permitted in the forum archives.<1331935121">
