Re: Bush Hog set up
Posted by K.LaRue-VA on July 12, 2012 at 15:17:34 [URL] [DELETE] :
In Reply to: Re: Bush Hog set up posted by RockyMO on July 12, 2012 at 12:35:55:
The unistrut and tube steel "rig" under the tractor is something I threw together to push saplings and brush down. It works a lot better than using the front axle, radiator, and headlights. I only need the one support in front because it's welded together and bolted to the "A" frame on the cutter. It can't tip and always stays level with the cutter. My intent is to replace the unistrut with something that looks a little better like black iron pipe.
Posting not permitted in the forum archives.<1342120654">
