Re: 2n 12 Volt question
Posted by Ed Gooding (VA) on July 26, 2025 at 20:49:03 [URL] [DELETE] :
In Reply to: 2n 12 Volt question posted by Steve_Pfost on July 26, 2025 at 17:24:51:
To check for adequate fuel, get a pint jar, remove the drain nut from the bottom of the fuel bowl on the carb and it should fill the jar in about a minute with a good stream of gas. If it does, then the next step would be to check ignition.
