In Reply to: Fuel bowl leaking posted by Larry Johnson on October 14, 2026 at 00:01:46:
You must determine where it is leaking rather than throwing parts at it.
Is it leaking at the bowl gasket? Is it leaking at the valve stem? Is it leaking at the tank/bowl assembly threaded connection? Is it leaking in multiple places?
Some leaks are more problematic than others.
