Re: what is it
Posted by raven on October 04, 2013 at 21:11:56 [URL] [DELETE] :
In Reply to: Re: what is it posted by TheOldHokie on October 02, 2013 at 17:31:22:
Does the gear pump work on UTF, 90 gear oil, 80/90 wt gear oil , hydraulic fluid?
1. all of the above
2. some of the above
Does the gear pump replacement use a separate fluid reservoir or OEM common sump?
How would the gear pump compare to a vane pump or OEM piston pump for the type of recommended fluid?
Just curious.
Posting not permitted in the forum archives.<1380935516">
