In Reply to: Re: 3 point lift question posted by JMOR on October 08, 2013 at 23:34:37:
Does not appear there is a seal in part #11.
So, can moisture easliy enter the chamber between the #11 plate and #14 shaft?
So once the linkage that is above the oil level is cleaned, could silver colored anti seize compound be applied to the joints or some other compound to prevent corrosion?
Posting not permitted in the forum archives.<1381326063">
