Re: Beginner Carb Adjustment
Posted by ASEguy on March 12, 2014 at 06:57:27 [URL] [DELETE] :
In Reply to: Re: Beginner Carb Adjustment posted by Steve9n on March 11, 2014 at 13:50:54:
Make sure you are getting fuel to the carb. Remove the plug in the bottom of the carb and let the fuel run out. It should run out like it's being poured through a straw. Let it run until it fills a regular Mason jar. I recently had a stalling issue with mine which has a new tank and sediment bowl and found a lint ball in the sediment bowl standpipe. It took two days to drain the 5 gallons out of the tank to remove the sediment bowl so I could remove the lint ball.
Posting not permitted in the forum archives.<1394625447">
