In Reply to: Old Warner gearbox...parts? posted by Mike-Ind on September 06, 2010 at 21:02:44:
find a bearing supply company. or the equivilent. . should be one around..we have one in shreveport, baton rouge, and lafayette. you may just need to pull the old seal, don't destroy it. there may be a part number on the face of it. take it in. they will measure it and give you something that will work. most shafts and housings fall within a standard sizes.. if the shaft is work where the seal rides. maybe a seal saver too. for twenty bucks, you can buy a set of electronic calipers. measure the shaft, and the housing opening. and the depth.. they can work from those numbers too.... charles
Posting not permitted in the forum archives.<1283824451">
