In Reply to: Bush Hog set up posted by Drake on July 10, 2012 at 23:19:27:
Limiter chains kits are commercially available for around $30.00. I use limiter chains on all of my rough cut mowers. Sorry no photos.
Yours does look to be a KK. Grease the tail wheel spindle and tail wheel bushing every time you use it.
Use a grade 2 bolt as a shear pin.
Unlike most, I keep my cutter blades sharp (unless cutting saplings when such is not advised due to puncture issues). Sharp blades will cutter cut better and require less HP and fuel. The trade off is faster blade wear.
Dean
Posting not permitted in the forum archives.<1341977929">
