Re: 8 Volt One Wire Alternator
Posted by Ed Gooding (VA) on August 30, 2026 at 09:48:56 [URL] [DELETE] :
In Reply to: Re: 8 Volt One Wire Alternator posted by Never Say Never on August 30, 2026 at 09:29:23:
Yes.
? - did you install a resistor in the wire from the terminal block to the coil when you installed the 8-volt battery? I am curious as to whether that is needed to protect the 6v coil. Also, did you tweak your regulator to charge an 8-volt battery after it was installed? If not, I question whether you were getting your battery back to 8v because the regulator would stop the charging before you got to 8 volts.
