Re: Generator Testing
Posted by Bruce (VA) on November 29, 2013 at 10:35:24 [URL] [DELETE] :
In Reply to: Re: Generator Testing posted by Tim Couch on November 29, 2013 at 10:13:19:
" How much does a 6v generator charge at?"
Unregulated, no load, about 18-24 volts as I recall. More than enough to melt the solder joints in the generator.
" What if the generator charges at say 12 volts. Will the VR stop letting current to the battery from the generator?"
That's exactly what it is supposed to do; limit charging voltage to about 7.5v.
" Do I need to see what the output of the generator is to adjust it to the correct output voltage?"
No. Use the flow chart. The v/r either works or it doesn't. Generators can be repaired, v/r's aren't.
Posting not permitted in the forum archives.<1385735724">
