In Reply to: Rear Worklight Project posted by Jon MI on July 22, 2010 at 08:55:07:
I've tried and don't believe the old bulbs are repairable. WHile you can un-solder the bulb the glass part is larger than the hole. It would appear that the bulb was soldered to the reflector, then the glass lens was crimped onto the relflector as an assembly sequence.
Posting not permitted in the forum archives.<1279803868">
