In Reply to: Re: Rear Worklight Project posted by John (TR) on July 22, 2010 at 09:04:28:
Yes, I believe the correct sequence is to remove the old lens, un-solder the old bulb, wire wheel or sandblast and prime the reflector, then solder in the new bulb, then mask it and paint the reflector with a hi-temp reflective paint, then re-crimp the lens back into place. I am guessing probably some touch-up on the outside of the reflector would be needed after re-crimping. Sounds like a lot of work doesnt it?
Posting not permitted in the forum archives.<1279804096">
