In Reply to: Re: 9N Won't Start posted by Jack - Iowa on October 18, 2013 at 10:25:45:
Hey Jack,
Okay, I put a test light on the sparks and all 4 were firing.
On the fuel side, I went to the extent of draining all the fuel, removed and cleaned the fuel bowel, filter, and upper area into the tank. Removed line into carb and carb, screen there was plugged and dirty. Verified good flow all the way to the screen into the carb but can tell if its getting into the carb.
You stated "three screens"...I found one top of fuel bowel, and one in-line carb...where did I miss one? Going back to check if I am getting anything from the carb drain plug.
Posting not permitted in the forum archives.<1382209978">
