In Reply to: Re: CABLE OVER HYDRAULIC STEERING posted by KCM on April 21, 2014 at 16:50:26:
Thanks for the responses guys, the cable part does work on mine and when its moving slow it can steer some. Maybe ill work on the cylinders before discarding the system. That little pin dies move slightly back and forth. Mine has a rubber boot covering next to it. Is that normal or did someone add that? Can you show a picture of your connection there? If i do replace the whole thing ill keep you in mind.
Again thanks for your attention, hopefully she will turn into something. I just replaced the fuel line and the fuel shut off that was leaking right onto the engine.
Posting not permitted in the forum archives.<1398130002">
