In Reply to: Re: 1951 8N Starting problem posted by K.LaRue-VA on October 01, 2009 at 23:35:21:
If the ring gear is loose on flywheel, you can weld it thru the starter mounting hole & avoid a tractor split.......have done more than once.
Posting not permitted in the forum archives.<1254454859">
