Re: 6 volt generator
Posted by Keith(CA) on November 12, 2012 at 10:59:18 [URL] [DELETE] :
In Reply to: Re: 6 volt generator posted by JMOR on November 11, 2012 at 16:07:26:
really want to ge this polarization thing correct
with positve 6 volt ground
1. External grd field, internal sourced field type A, 2 brush
polarization: field terminal to negative bat terminal
2. External grd field, internal sourced field, type A, 3 brush
3. Internal grd field, internal sourced field, type A, 3 brush
polarization: armature terminal to negative bat terminal
4. Internal grd field, external sourced field, TYPE B, 2 brush
NAA model
Is the above correct, want get it right!
Understand the field is not permanent magnetics so the iron core must magnetized with the wire coil. The polarization gets the current working in the same direction as the armature generated current for a shut wound generator where the field coil and armature are in parallel.
Posting not permitted in the forum archives.<1352735958">
